*setsubmodeltype
Sets the sub-model type supported by ID manager.
*setsubmodeltype type
HyperMesh Tcl Modify Command
- type
- The sub-model type. Valid values are HM_INCLUDEFILES and MODULES.
To set the sub-model type to MODULES:
*setsubmodeltype MODULESErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
